u joint problem
Old Aug 30, 2009 | 02:41 AM
johnsbp's Avatar
johnsbp
Default u joint problem
So i have been having noise issues from under my car. When i looked under the car i noticed there was a ring (about 3 inch long and 5 inch in diameter) free floating that looks like it would cover the u joint closest to the transmission. It has two holes side by side each other and im fairly certain this is whats causing the noise. What is this ring or collar called and is it supposed to be bolted near the u joint? Has anyone else had this problem before? Just looking for some insight into the problem.
thanks,
-Ben
Old Sep 2, 2009 | 01:34 AM
hiboostwoody's Avatar
hiboostwoody
If it's just rattling around on the driveshaft it's probably pretty likely that is the cause of the noise. We ****can those when we do tranny jobs just for that reason.
Old Sep 3, 2009 | 09:29 PM
capri man's Avatar
capri man
cut it off and forget it!!
Old Sep 5, 2009 | 03:01 PM
radlo420's Avatar
radlo420
happened to me its kinda ****y but take the drive shaft out its easier and safer than cutting it off
Old Sep 7, 2009 | 01:46 AM
johnsbp's Avatar
johnsbp
just took the driveshaft out today and removed the collar. solved all my problems and now im back in buisness. Thanks everyone for your help!
Old Sep 7, 2009 | 04:20 AM
GreenMachine19's Avatar
GreenMachine19
good to know you solved the problem
mtgldr
Feb 3, 2024 09:00 PM
guitarman376
Oct 11, 2015 01:47 AM
gagemcc
Sep 22, 2015 09:43 AM
stangin1996gt
Sep 21, 2015 11:01 AM
trashxtrash
Sep 20, 2015 10:49 PM
