88 Ranger help?
Old Sep 1, 2009 | 12:13 AM
DuFFMaNN's Avatar
DuFFMaNN
Exclamation 88 Ranger help?
I am in the middle of acquiring a 88 ranger from my aunt. It has been sitting for the past 3 years so I am not even sure if I can get it to start. I know I need to get the bad gas out of there, change the fluid, air/change tires, and new battery. Is there anything else I would need to do?
Also the reason it sat for so long is that when you would have it in first gear idling, if you did not constantly give it gas, it would die. Any ideas on what would cause this? Possible fix's?
I am on a very tight budget at the moment as I am a student and pay all my out bills.
By the way, my long term plan is dropping a 302 in it.
Edit: It is the 2.9l v6
Old Sep 1, 2009 | 02:05 AM
GreenMachine19's Avatar
GreenMachine19
after you do the above plus oil change (if thats what you meant by fluid) and fuel filter, maybe spark plugs/wires but not necessary yet
you can check the IAC, MAF, and TPS in that order to help with the idle
Old Sep 1, 2009 | 12:53 PM
DuFFMaNN's Avatar
DuFFMaNN
Okay. Ya i meant oil. ha.
So whats the best way to get rid of the old gas? Do I have to go in, and actaully just drain it out, or burn through it or ...?
Thanks for the help.
Old Sep 1, 2009 | 02:51 PM
GreenMachine19
not sure on that one man, maybe syphen as much as you can and then fill it with fresh?
use the old stuff in your lawnmower maybe
Old Sep 1, 2009 | 03:45 PM
Riptide's Avatar
Riptide
Suggest posting on rangerstation.com
Old Sep 1, 2009 | 04:59 PM
DuFFMaNN's Avatar
DuFFMaNN
Okay thanks. I posted on Rangerforum.com and Fordforum.com but both are very low activity. I will check that one out!
Old Sep 1, 2009 | 05:17 PM
Riptide's Avatar
Riptide
btw it's therangerstation.com
I left out "the" on the previous post
col2560
Sep 25, 2015 08:59 PM
BlackMage
Dec 20, 2004 01:13 AM
Obsol3te
Feb 25, 2004 06:04 PM
