Coolant leak
Old Sep 2, 2009 | 03:15 AM
Tiger6732's Avatar
Tiger6732
Default Coolant leak
I have an 89 lx 5.0 and I had an issue with coolant leaking from what i thought was the water pump so I replaced it and started to add anti-freeze and all of the sudden coolant started leaking again. It appears to be leaking somewhere above the water pump but even with a flashlight and sticking my nose directly near the flow I can't seem to see where it's coming from. Has anyone else had this problem or knows what could be causing this leak pleeeeaaassseee help. I also checked thermostat housing and nothing there either. Any help or suggestions would be great thanks!
Old Sep 2, 2009 | 03:23 AM
michaelross's Avatar
michaelross
check the radiator.. then if its not it, then check the intake manifold gasket. it may need replacement already.
Old Sep 2, 2009 | 03:25 AM
Tiger6732's Avatar
Tiger6732
yeah definitley isnt radiator but I will check the intake gasket thanks a million!
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
