Tranny problems...
Old Sep 20, 2009 | 10:23 PM
RichB's Avatar
RichB
Default Tranny problems...
So I got a 2000 GT 5 speed with 80K+ miles and well anyway when i first bought it shifting and going into gear was never a problem....Now recently like the past 2 weeks its been giving me trouble, Its extremely hard to go into first gear and even driving and shifting I have put some power to change the gears now, reverse is nearly impossible to get into unless I put it in Reverse before the car is turned on..Anyone know what the problem could be?
Old Sep 21, 2009 | 11:51 AM
FlamingoGT's Avatar
FlamingoGT
Maybe the clutch cable needs adjusted? Also make sure the floor mat isn't getting jammed up behind the clutch pedal... mine is always doing that and it makes for harder shifts.
Old Sep 23, 2009 | 04:23 PM
Jfsram's Avatar
Jfsram
Most common is the cable is too loose, maybe the pilot bearing is dragging the input shaft or the disc is falling apart and dragging on the flywheel.
How far up off the carpet is the pedal when the clutch starts to engage?
Old Sep 24, 2009 | 12:24 PM
RichB's Avatar
RichB
I really doubt its the floor mat its nowhere near the clutch, I cant get it into gear at all anymore....Maybe its the synchros or something? and once its in like first gear and I hold the clutch down it makes a weird noise like "whiiiissssshhhhhh" or something like that.....Reverse takes Like 50 tries just to get into
thanks fellas, Im really trying to figure out what the problem is....
Old Sep 24, 2009 | 06:24 PM
gareth92's Avatar
gareth92
i agree its most likely a lose cable but you may wanna check ur shifter knuckle where it meets the trans it may slide too much
Old Sep 26, 2009 | 07:09 PM
RichB's Avatar
RichB
can a loose cable do all that? I mean It doesnt go into gear and it makes a weird sound once its in gear and you hold down the clutch. I will check it out though, thanks guys
Old Sep 28, 2009 | 07:01 AM
1992 Drop Top 5.0's Avatar
1992 Drop Top 5.0
That sounds identical to my 1992 5.0 5 speed; the last time I had this problem the cable snapped after that it was fine, I was told the cable stretches before it breaks. Now a year later I am seeing some of the same issues.
Old Sep 28, 2009 | 07:55 AM
mrdeep2001's Avatar
mrdeep2001
i have an issue with getting it into reverse sometimes also even with the car off. trick is to hold the clutch in, put it in 5th, and then reverse. i dunno why but it works...
Old Sep 28, 2009 | 05:29 PM
SpitnCobra's Avatar
SpitnCobra
1.syncronizers.......if your a cluth rider 2. Stretched cable will do the same thing, mine done it on my 92GT replaced it with a BBK firewall adjuster & new cable no more problems.....Good Luck
Old Sep 28, 2009 | 05:53 PM
mrdeep2001's Avatar
mrdeep2001
i suppose it could be either, i dont know when clutch cable was changed last, and tranny has over 200k on it...
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
