Caliper Question
Old Jul 13, 2005 | 01:04 AM
Fishhawk's Avatar
Fishhawk
Default Caliper Question
Threw on a new set of rotors on my 85 GT. When I get to the calipers I can't get the caliper piston to push back. If anything its pushed out more. Any secrets to moving a stubborn piston or do I need new calipers. They are the original calipers, but with only 67,000 miles.
Old Jul 13, 2005 | 08:45 AM
Djs94stang's Avatar
Djs94stang
Default RE: Caliper Question
If the piston is not easily compressed back in the bore, it is likely that you need a new caliper. Even though the mileage is low, time has a lot to do with the pistons getting stuck. Corrosion usually will take place more rapidly when the car is driven less depending on the atmospheric conditions.
Old Jul 13, 2005 | 11:19 AM
99saleen351r's Avatar
99saleen351r
ya most likely its siezed if it doesnt move, you can try pulling back the rubber boot and spraying it with wd40 but most likely you need a new one cause if it sticks out it will ruin the rotor and pads
Old Jul 13, 2005 | 11:24 AM
Fishhawk's Avatar
Fishhawk
Thats kind of what I was thinking. I've tried everything I can think of to move it. Tool specificely designed for it, the c-clamp trick, putting the pads back in and trying to pry it open with a large screw driver. Even pulled about half the fluid out of the MC. No dice.
A reman. claiper is under $20, so I might as well get two and be done with it.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
