Tire wobbling
I was screwing around and my rear tire slammed against the curb and cracked my rim. I bought a new rim and bought new tires because they were worn out. Now my tire is wobbling. I'm thinking it's probably my axle. Could it be anything else? How much do new axles cost to have my mechanic replace it?
Oviously she didnt read it cause it says rear, and you cant see the axle from underneath its in the rear end tubeand there is no front axle but anyways the axle is fairly cheap I acually have a couple and to put it in should only take about a hour or so.Its definatly the axle that happens all the time dont sweat it.Bet it cost 150 with the part 200 most
ORIGINAL: GreyStang
What kinda car is it? Got rear disk or drum brake? Is the brake rotor/drum screwed up too?
Also probably gotta replace the outer wheel bearing during the repair too..
The drum and or rotor are fine that doesn't usually get bent its the axle it happens all the time
jwog666
Dec 27, 2021 08:09 PM
KingRando
Oct 2, 2015 08:06 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
