Help. v6 94 stang
Old Oct 7, 2009 | 03:16 PM
jr0c1's Avatar
jr0c1
Default Help. v6 94 stang
ok .well........... i had an problem with my transmission slipping with transmission fluid leaking out from ounder the right side of the car by the passenger wheel , well got that tooken care of a nd was told that my gaskets had gotten broken ... . after i got that fixed.... for an good $80.00
now the check engine light is on............and it seems like my car is all conjusted....... i have to push it down far to hard for it to stay @ normal speed of traffic......and also.........it smoked up one time from the engine.
basicly i went to this one shop that had nothing to do with engines.....that i got my breaks done on.. and had them check it with the machine . he told me that left side was 2 lean and maby he needed to fix my eletric control because it might not be reading my gas level or something........
basicly i dont have the time right now 2 get an check up for about another 2 weeks. is the car safe 2 drive ? its running real conjusted. and stuffy. has any one had this problem? ithought itwas the transmission so i got that checked now its the check engine light and not slipping but running reall stuffy.........any answers? thanks alot guys!
Old Oct 8, 2009 | 02:25 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Can someone translate for me?
Matthew
Old Oct 8, 2009 | 02:30 PM
jr0c1's Avatar
jr0c1
ok...............lets try this again....sorry guys..........
i have an 1994 mustang......... its running real slugggish.............. wont pick up gears thats fast...........the check engine light is on.................engine smoked up white smoke once............... when i start the car it has a loud rattling sound when i push the gas................. any one know whats going on />?
i took it to a repair shop they said left side 1 on lean..............i dk wtf that is ...but does any 1 know ?
Old Oct 8, 2009 | 04:14 PM
dreamer1uk's Avatar
dreamer1uk
Hi,
The o2 sensor on bank one is indicating a lean running condition. Basically theres too much oxygen left over from the combustion cycle on bank 1.
You can test most o2 sensors with a DVOM and your going to be looking at how quick they can switch. The usually switch from 0.2 to 0.8 millivolts. Id also look for vacuum leaks, checking the fuel pressure, checking the pulse-width of the injectors and so forth. Places like Autozone will loan out Noid lights to so you can check to make sure the injectors are been fired. Any cracks in that banks exhaust manifold or pipe will also give false readings to the o2 sensor.
If you can find somone with a good scan tool, you will be able to check alot of the freeze frame data ect as well as conducting a cylinder balance test and so forth.
Hope this helps.
Old Oct 8, 2009 | 05:46 PM
jr0c1's Avatar
jr0c1
yesssssssssssssss thankkks man ,....this guy is sup3r
Old Oct 8, 2009 | 05:52 PM
jr0c1's Avatar
jr0c1
so basicly go check out the exhaust and get the o2 sensers checked at an engine shop ?
Old Oct 8, 2009 | 08:20 PM
dreamer1uk's Avatar
dreamer1uk
Hi,
You can test the o2 sensor yourself with a DVOM or Volt meter but you would need a wiring diagram so you know which wires to probe.
I would still check the engine over for vacuum leaks and such like i stated n my previous post and go from there. The o2 sensor may and probably is fine and not the problem but o2 sensors will become 'lazy' after around 50k miles.
Now if you observed white smoke coming from the exhaust, you may have been burning coolant. Make sure you check your coolant level. You could even pull a few plugs to see how they look. Is they look like new and you know there several years old, you know that your burning the coolant. You can also check your oil for a 'milky' residue.
For the loud rattling sound, can you describe that alittle more in detail? Does it sound like valve tapping, rods knocking ect?
Old Oct 8, 2009 | 08:50 PM
mustang51js's Avatar
mustang51js
the rattling is prob something with catalytic converter
Old Oct 9, 2009 | 01:11 PM
jr0c1's Avatar
jr0c1
well the rattling sounds . come when i stop like if im in a drive thru. the car starts to rattle ....... then i have to get off the break and move up a little and get back on them harder . but then it starts to rattle more. or when i drive it will rattle ratlle a lil when i step on the gas.....idk but it sounds like its comeing from under the car. but when im in drive thrus . im trying to understand why it rattles when i break? but wont rattle when i put it in park and the car is still running/
Old Oct 9, 2009 | 09:27 PM
dreamer1uk's Avatar
dreamer1uk
Hi,
Does it sound like more of a vibration than a rattling noise?
Have you had someone place the vehicle in drive and popped the hood and inspected the engine bay while they have here foot on the brakes (and the parking brake too )?
I would look at the exhaust area and check for a loose heatshield, corroded hangers and so forth.
Remember that when your in park or neutral, the engine is free-wheeling, where as if its in gear and you have your foot on the brake, its under a load still, if that makes sense.
Hope this helps somewhat.
flash_xx
Sep 21, 2015 01:25 PM
da boss
Jan 1, 2006 07:21 AM
tiger
Dec 15, 2005 11:47 AM
00limited7
Oct 11, 2005 01:37 PM
2004 GT RagTop
15
Jan 17, 2005 03:00 AM
