crank pulley replacement
Old Oct 21, 2009 | 07:37 AM
craigh4575's Avatar
craigh4575
Angry crank pulley replacement
I bought a set of aftermarket pullies, and got the alternator, and water pump pulley off fine. I cannot for the life of me get the crank pulley off. I have tried pb blaster, in conjunction with an impact gun, and also using a breaker bar. Can anyone help with some ideas on getting this off. It is driving me crazy not to be able to drive it.
Old Oct 21, 2009 | 07:35 PM
sv650lex's Avatar
sv650lex
Do you mean just getting the bolt loose or actually pulling the pulley? To get the bolt loose if your inpact wont do it put it in gear and set the parking brake. Then take your breaker bar and a pipe for leverage and turn it. If you mean pulling the pulley off, you will need a harmonic balance puller.
Old Oct 22, 2009 | 12:49 AM
hiboostwoody's Avatar
hiboostwoody
You can also put your breaker bar on it wedged up against something solid in the engine compartment, disconnect the coil(s), and bump the starter over. I have done this numerous times (espescially on Subarus and Hondas) and it works great.
Jb145700
Aug 21, 2022 06:37 AM
OSUTX440
Ohio Regional Chapter
Mar 15, 2021 09:27 AM
5.0muscle
Jan 11, 2016 01:17 PM
Golfsito
Oct 6, 2015 11:02 AM
StalkerGT
Sep 25, 2015 02:41 PM
