Steering shaft.
Old Nov 14, 2009 | 03:12 PM
Jfsram's Avatar
Jfsram
Default Steering shaft.
Installing some long tube headers. Seems like the steering shaft needs to be disconnected/removed. There is a through bolt at the top end that holds the flat shaft together, the rag joint or the connection into the rack/pinion assembly.
Which connection needs to undo to get the steering shaft out of the way?
Old Nov 14, 2009 | 07:56 PM
MU71L4710N's Avatar
MU71L4710N
this is one of the better writeups everyone uses.
http://www.fnsweet.com/garage/lt_install/index.shtml#11
Remove the steering shaft nut from the bottom of the shaft where it connects to the steering box using a long extension and 13mm socket. Turning the steering wheel helps to expose the bolt. The bolt is accessed through a cutout in the K-member right behind the spring on the driver's side or from underneath the car. Pull the shaft off of the steering box. The shaft is comprised of an inner and outer sleeve. The inner sleeve can be retracted into the outer sleeve when you pull it off of the steering box.
Old Nov 15, 2009 | 09:37 AM
Jfsram's Avatar
Jfsram
How about for a 93?
lincolnshibuya
Dec 8, 2020 01:49 PM
CS2007
Jun 25, 2019 09:45 PM
ChampInSD
Oct 2, 2015 04:55 AM
allenmaty
Sep 24, 2015 09:17 AM
stark777
Sep 21, 2015 12:46 PM
