heat issues?
Old Dec 7, 2009 | 07:25 PM
chevyguy69's Avatar
chevyguy69
Default heat issues?
Ive replaced heater core, thermostat, heater hoses and i have hot water flowing into my heater core the **** to switch from hot to cold is broke but i turn that manually. I have switched the hoses around and tried turning my hot cold selector both ways and i cant get any heat. If anyone has any ideas i could use some help im freezin my nads off!!!!!
Old Dec 7, 2009 | 09:07 PM
chevyguy69's Avatar
chevyguy69
I have a heater hose going from intake to heater core that has hot water runing through it. Where should the other hose be hooked up?
Old Dec 7, 2009 | 11:24 PM
hiboostwoody's Avatar
hiboostwoody
Your heated air door actuator is probably bad.
Old Dec 8, 2009 | 12:18 AM
chevyguy69's Avatar
chevyguy69
Im not exactly sure what a heat actuated door is but im assuming you are talking about the door that lets air in or blocks air out of the heater core and that seems to be working fine. For some reason when i checked to c if hot water was getting to my heater core only one of the hoses was hot which doesnt make much sense to me.
Old Dec 8, 2009 | 01:24 AM
hiboostwoody
You may have a plugged heater core. Take both hoses off and see if you can blow air through the core. Don't use a too much air to keep from rupturing the core.
Old Dec 8, 2009 | 04:59 AM
RogerDodger1's Avatar
RogerDodger1
Just replace EVERYTHING in the heating/cooling system and that might do the trick. Then if that doesn't work, just replace the entire car.
Nick Oliver
Oct 17, 2018 04:22 AM
PaulH2
20
Jan 31, 2016 09:48 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
