oil change time
Old Jul 21, 2005 | 04:23 PM
92hatchLX's Avatar
92hatchLX
Default RE: oil change time
Do you not do your own oil changes? That's a helluva lotta money for an oil change.
Old Jul 21, 2005 | 04:46 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
no point for synthetic if you change oil every 3000 miles. That's what the chemical engineers I know say. but what do they know anyway? ask the dudes at pep boys instead. The reason for synthetic is that it lasts longer before breaking down, and it supposedly has better detergent properties, but you only need those detergent properties if you don't change your oil every 3k miles.
Old Jul 21, 2005 | 05:36 PM
sandcracker21's Avatar
sandcracker21
so would i still need to change my oil every 3 months or 3000 miles if
i use a sythetic blend, say.....mobil 1 5w20 in my 03GT?
Old Jul 21, 2005 | 07:28 PM
sandcracker21
i got a really good deal on a case of castrol sythetic with a napa gold filter
its 5w20, will this work?
sorry iv only had my baby for 4 months now and its my first oil change on a ford
Old Jul 22, 2005 | 03:04 AM
NewMexMustang's Avatar
NewMexMustang
That should work. As long as you change your oil every 3k or however long the synthetic says, anything should work fine. I only spend like $14 on my oil changes (I've used Havoline and Valvoline w/ Fram tough guard), but I always change the oil every 3k.
Old Jul 22, 2005 | 05:16 PM
sandcracker21
doesnt sythetic last much longer then 3k?
Old Jul 22, 2005 | 05:19 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
I think you "can" change synth every 6000 miles. Actually, if you look in the scheduled maintenance booklet that came with your stang, it recommends an oil change every 5k miles, not 3k.
Old Jul 22, 2005 | 05:55 PM
sandcracker21
well its time to change tomorow and do a lil inspection to see if any of my other fluids or anything are low,
wut else should i inspect while im changing my oil and other such things
thanks for the input
Old Jul 22, 2005 | 06:04 PM
gettna05!'s Avatar
gettna05!
I've used syth now for 10 yrs on all my cars with 10k mile changes. I offset the higher price by changing the oil (myself) half as often, which is GREAT. According to everything I've read (a lot of stuff), good syths like Mobil 1, Amsoil, Redline can go 18-20k miles before any big change in performance. Also syths don't loose their additives like regular oil. They just need to have the filter changed at 12k to get the dirt out. so an oil change at 10k works fine. at least it has for me. the price up-front still looks high. $5 for one little quart. My stang needs 6 of those things....
Old Jul 22, 2005 | 06:43 PM
NewMexMustang
Different synthetics are engineered to last different lengths of time. They say on the bottle.
