water pump question
Old Jan 14, 2010 | 10:17 PM
jd's65coup's Avatar
jd's65coup
Default water pump question
what is the difference in a water pump for 1986-93 for a 5.0 mustang vs. the water pump for 1985 5.0.
part store has the water pump for 86-93 is in stock but not for the 85.
i got a 90 gt with a motor and trans out of a 84 gt. i know it will bolt up just didnt know if there was a difference in water flow or something.
Old Jan 14, 2010 | 10:36 PM
67mustang302's Avatar
67mustang302
The difference in pumps throughout the small block Fords are which side the hose inlet is on and whether it's standard or reverse rotation. It's probably that 86 was the first year they used a reverse rotation pump. I can't remember for certain though.
Old Jan 14, 2010 | 11:19 PM
jd's65coup's Avatar
jd's65coup
i thought the rotation was the same but i could be wrong. if i remember right the serpentine belt runs the same.
Old Jan 15, 2010 | 02:55 PM
67mustang302
It could be the radiator inlet then, the outlet and the rad was on different sides so the inlet and the water pump switched as well. But I thought that switch was made in the 70's.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
9550
Oct 26, 2015 05:01 PM
96stang3.8
Sep 10, 2015 06:42 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
