2010 mustang help
Old Jan 17, 2010 | 02:51 PM
H911STANG's Avatar
H911STANG
Default 2010 mustang help
i have a 2010 mustang, basic model with the skipper 500 system in it (ironically i have had no issues with it). But i recently bought a subwoofer/amp for some aftermarket sound, and i need some help installing it. i would much prefer to run it off of the back of the unit, but i dont know if there are some other options out there. any help is much appreciated
Old Jan 17, 2010 | 05:28 PM
KoolerSL2's Avatar
KoolerSL2
most ive seen shops and people do get a line output converter and hook it up to the rear deck speakers.
since the factory dont have any low level outputs on the back.
Old Jan 17, 2010 | 06:57 PM
Snitz's Avatar
Snitz
run all ur usual power/grounds/power control wires and go pick up a hi/lo converter, the converter will allow you to splice into your two rear speakers and will convert that to rca's then just plug the rca's into the hi/lo converter and the amp and you should be good to go =D good luck
Old Jan 17, 2010 | 09:13 PM
H911STANG's Avatar
H911STANG
thanks a ton fellas!
i was reading on my amp and it says it has low level inputs, does this mean i need that converter still?
Old Jan 19, 2010 | 05:30 PM
H911STANG's Avatar
H911STANG
Good news! I successfully (with 4+ hours of struggling and trial n error) installed my subwoofer + amp. it feels like i can get more bump out of it. anybody know any tips/tricks on how to get it to really POP?
Old Jan 20, 2010 | 07:02 PM
onlymustangfords's Avatar
onlymustangfords
Quick answer to your second last question about a converter. Yes. The line input is low, but the rear speaker output is high, that's why you have to convert to a low output.
Last question: Check into the better capacitors for more punch.
Old Jan 21, 2010 | 04:22 PM
Fobra's Avatar
Fobra
Banned
You need a new head unit with a real independent output.
2014V6Stang
Aug 19, 2015 03:24 AM
Loristic
Aug 17, 2015 10:56 AM
Barcafut13
Aug 13, 2015 08:05 AM
daytooday
Aug 11, 2015 09:22 AM
elraun
3.7L V6 Technical Discussions
Aug 9, 2015 04:32 PM
