Belt Issue GT500 ??
Old Feb 14, 2010 | 05:03 AM
GT500Whipple's Avatar
GT500Whipple
Default Belt Issue GT500 ??
I replaced the stock pulley on stock blower with a 2.6 pulley package from lethal perf idler and all installed the car was great for 6 months then ripped one rib off the belt i changed the belt and it happened again afew days later it is taking the rib off the front of the belt so i am thinking the pulley has either become mishaped some how or is in too far anyone have a spec for alignment of this pulley these 10 rib belts are hard to find and exspensive so any advice before i try again is greatly appreciated thanks in advance
Old Feb 14, 2010 | 06:29 AM
Mach1Marauder's Avatar
Mach1Marauder
Tensioner is prolly bent or the last belt wasn't installed correctly.
Old Feb 14, 2010 | 01:24 PM
luckythirteen13's Avatar
luckythirteen13
make sure none of the pulleys or the brackets that hold them in place have come loose causing a missalignment. also check the pulleys while the motor is running and see if any wobble.
i had a similar issue back when i had a vortech sc, the belt would jump one rib forward under wot. in the end, it turned out to be the tensioner pulley wasnt parrallel with the rest of the pulleys it was angled just barely, couldnt even see it with the naked eye, had to use a straight edge to find the problem
Old Feb 15, 2010 | 07:32 AM
GT500Whipple
Thanks guys remembering what a **** sucker it was to get that belt on i'm thinking i did bend the tensioner. never would have thought of it. really apreciate it. this is definately the best forum around
FivePointToTheOh
Mar 9, 2020 10:26 PM
FivePointToTheOh
Sep 29, 2015 12:53 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
Other Professional Racing
Sep 10, 2015 11:41 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
