Rear axle end assembly
Old Feb 24, 2010 | 10:35 PM
jrmyelam411's Avatar
jrmyelam411
Default Rear axle end assembly
I have a 97 Mustang GT. I need to get the rear end replaced and found some ones that are in good shape. My question is that I understand I need an 8.8 rear end axle assembly, but what I don't know is do I need an 3.08 or a 3.27? I'm not familiar with this. I do not have posi-traction now either. Any help or advice as to which to get so I can get my mustang running good again would be great. Thanks again for all your help.
Old Feb 25, 2010 | 04:55 AM
Detailer_Dave's Avatar
Detailer_Dave
There may be a tag on one of the differential cover bolts that will provide the info you seek. Auto or manual trans makes a difference too. The manual trans probably would have the higher number.
Old Feb 25, 2010 | 09:23 AM
jrmyelam411
I have a manual transmission. And I found out that the numbers 3.08 and 3.27 are gear ratios. So you believe it is the higher number for me?
Old Feb 25, 2010 | 11:20 AM
Detailer_Dave
It is a good possibility, but check for the existence of the tag first, rather than play guessing games.
Old Mar 4, 2010 | 09:04 PM
Jfsram's Avatar
Jfsram
Get the 3.27 and a GT should have come from the factory with a TracLok rear.
Nov 10, 2015 11:39 AM
musnicki
Sep 23, 2015 07:11 AM
Dragonus18
Sep 9, 2015 01:21 AM
Sep 3, 2015 07:14 PM
cbird1177711
Sep 2, 2015 08:51 PM
