Overheating Help!
Old Feb 26, 2010 | 01:20 PM
kibblor's Avatar
kibblor
Default Overheating Help!
Ok, since noone helped me in the 4.6 forum ill post it here.
(Ok i sort of know whats wrong)
Ok so heres the deal, i had a dead battery, i replaced it and eveything was good, checked all the fuses for battery drain and all that, but recently i was like...hmmmm....my heat guage is a tad bit more up than it is supposto, so i brought it home and looked, i realise nomatter how hot it is, moving or not, the radiator fan is not running *gasp* whats wrong X3......oh...and the low coolant light thing stays on, yes it is full and i double and triple checked, all the cables are plugged in...the light just stays on. Help me oh knowledgable mustang gurus
It only overheats when its sitting still, but what would cause the light and the fan to both trigger?
Old Feb 26, 2010 | 11:28 PM
Semloh's Avatar
Semloh
Default related
So from the way you described it the overheating problem started after you changed the battery?
If so then possibly when you were doing you battery drain testing thingy you didnt get the fan fuse back in good.
The reason its getting hot only when sitting still is because the fan isnt coming on. When you drive enough air flows in to keep it cool enough.
It may be that the low coolant switch uses that same power.
Old Feb 27, 2010 | 02:04 AM
kibblor's Avatar
kibblor
GOoooood question...but i pulled all the fuses and checked them, i dont know which fuse is the fan one :\
Old Feb 27, 2010 | 10:57 AM
chronos's Avatar
chronos
Then it looks like you have to go back and recheck them all again. Make sure power is actually getting through them. Sometimes a fuse will look good, and be blown. A simple way to check if your fan comes on or not is to kick on your AC. On these cars the minute you click on the AC the fan starts and runs until you turn it off.
BOB ROME
Jul 26, 2023 01:54 PM
mungodrums
Sep 29, 2015 09:18 PM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
