Mach 1000 Electrical Question
Old Mar 11, 2010 | 09:15 PM
StreetSaleen61's Avatar
StreetSaleen61
Default Mach 1000 Electrical Question
I put a Factory Mach 1000 stereo from a 2002 Mustang stereo in my 2000 Mustang but I retained the original radio/CD player. A problem I ran across is the power-on signal coming from the radio is 4.4 volts with the original 3 amps plugged in and the new Mach 1000 amps require 7 volts to turn them on. It seems like I need a relay that would turn on with the 4 volts coming from the radio power-on signal and a resistor to drop the 12 volts from the battery to 7 volts to turn on the new amps. An alternative would be to use a 7 volt power supply that could be turned on by the 4 volt radio power-on signal. My question is, which one of these approaches would be better and where can I find a relay that would turn on with 4 volts?
Old Mar 22, 2010 | 08:40 PM
ga chopper's Avatar
ga chopper
any radio shop should have the module i thing is about $45.00
Big Al's 03
Sep 15, 2015 09:05 AM
TfcCDR
Sep 14, 2015 12:08 PM
cbird1177711
Sep 3, 2015 08:43 PM
iamgobono
Sep 3, 2015 12:37 PM
cbird1177711
Sep 2, 2015 08:51 PM
