98 cobra no start
Old Mar 11, 2010 | 09:16 PM
charlieb's Avatar
charlieb
Default 98 cobra no start
Hey guys. Need some help with my girlfriends 98 cobra. She started the other morning and it had a miss. I went out and started it and it felt like a dead cylinder. Shut it off and it wouldnt start again. Lucky for her (not so much for me) I am a GM technition. Have been for 12 years. I checked fuel pressure, cranking it is at 38 psi. Check spark, got spark at all plugs. Have injector pulse on all injectors. Check compression and all comp seems low... 85-75. Thought maybe timimg chain "jumped" pulled front cover to find timimg chain in tact. So here I am scratching my head..... any help would be greatly appriciated.... dont want to get rid of the girlfriend so breaking up with her is out. : )
thanks
Charlie
Old Mar 11, 2010 | 10:30 PM
a_penquin's Avatar
a_penquin
The timing didnt jump, these are zero tolerance engines and it would be much worse if it did. By injector pulse, Im guessing you checked the signal at the harness and not the injector itself. If it starts again one by one pull the harness from each spark plug wire and check for a change in engine response (harness from the COP if coil on plug). If you find one that dosent change you found your dead cylinder. Check the plug to see if your actually getting spark though the plug. If this all checks out, check the injector itself. It could be shorted inside, worn out, clogged, ect.
Old Mar 12, 2010 | 07:51 AM
charlieb's Avatar
charlieb
It wont start now. It acts like it is out of time. Is there a crank/cam sensor issue i should look for? Im going to scann it for codes tonight.
Old Mar 12, 2010 | 10:44 AM
a_penquin's Avatar
a_penquin
scan it for codes would defiantly help, if you pull any, post them up and we can help out more. The crank sensor could very well lead to this, but I dont want to lead you into a part swapping fiasco. Hopefully you can get some codes up, or someone will chime in with they're experience.
Old Mar 13, 2010 | 07:22 PM
charlieb's Avatar
charlieb
Well I found the problem. After thinking about it overnight, I remembered the Northstar engines doing the same thing with cam sensor issues. So I bought a cam sensor from the dealer. The parts guy gave me two pigtail wires for the connector as well. He said the techs always asked for the wires as well. So I get home and go to pull the sensor out, and found the wire insulation deteriorated and the bare wired contacting each other. So I replaced the wires and the sensor. Fired right up!!!
Old Mar 13, 2010 | 07:25 PM
a_penquin's Avatar
a_penquin
congrats, I'll keep that in mind for next time and should probably check mine, any hint to location?
2007StangV6
Jan 28, 2016 06:09 PM
Nov 10, 2015 11:39 AM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 06:25 PM
5.0 kevo
Sep 3, 2015 06:24 PM
