loss power engine codes
Old Mar 20, 2010 | 03:47 PM
mustangmike05's Avatar
mustangmike05
Default loss power engine codes
I have 05 V6 5speed manual 39k miles. The problem I've had intermittenly. Hesitate and/or stall with loss of power. Check engine codes are P2106,P2135,P061B,P2104 & P2111. What is this ? How easy or hard to repair ? thanks for any help.
Old Mar 20, 2010 | 11:59 PM
hiboostwoody's Avatar
hiboostwoody
Code P061B is a code indicating a torque calculation error by the PCM. The causes of this code are the same as the causes of code P2106. Code P2106 indicates that the Throttle Actuator Control (TAC) system is in a failure mode of "Force Limited Power" due to a concern of the Electronic Throttle Control (ETC) system or its components. This can be an effect of a problem in another vehicle computer system such as ABS / Stability Assist, the Instrument Cluster Module (ICM) or other systems. Codes P2104 and P2111 are throttle body related. In most case a throttle body failure will be the suspected cause of these codes. Code P2135 is caused when the PCM flags a concern indicating that the Throttle Position Sensor 1 and sensor 2 disagree by a calibrated limit. This is sometimes caused by a blockage of some kind in the throttle body or some other thing not allowing the throttle body to open or close all the way. The first thing I would do is check to make sure you don't have something stuck in there like a mouse. It's probably not likely but I'd check it out anyway to eliminate it. After that I would say you probably need a new throttle body. Hope this helps.
Old Mar 22, 2010 | 04:13 PM
mustangmike05
thank you hiboost. I figured its all related. The car runs great except when it "acts up" Hopefully TAC is loose or dirty. Thanks again.
Old Jan 7, 2025 | 01:08 AM
Heftyman02's Avatar
Heftyman02
Default Sorry I’m late
what exactly would cause p2106? My Mustang is doing so and I can’t figure it out I’ve changed everything throttle body related
Old Jan 7, 2025 | 04:01 AM
Heftyman02's Avatar
Heftyman02
Redrum2.0
Jan 2, 2017 06:13 PM
Uncle Paw Paw
3.7L V6 Technical Discussions
Dec 24, 2013 02:23 PM
GT 555 KING SNAKE
Sep 28, 2012 10:04 PM
freefallpat
Dec 18, 2007 06:51 PM
massivestunna
Feb 21, 2007 05:31 PM
