Driver side window wont roll up or down...help
Old Apr 24, 2010 | 06:58 PM
02v6Muscle's Avatar
02v6Muscle
Default Driver side window wont roll up or down...help
A while back I was rolling down my driverside window and it started making a noise when I was rolling it up and right before it rolled up there was a pop! After the pop I could hear the motor spinning freely but the window won't move, I can pull or push the window up or down with ease now with my hand.Do you think the window is off track? When I look inside the window crack I can see the motor spining but looks like the arms arnt attached or anything can anyone help me? Thank you!
Old Apr 24, 2010 | 07:07 PM
petrock's Avatar
petrock
Sounds like the window came off the window regulator. Take the door panel off and have a look inside. Should only take a couple minutes to find out. Hopefully the window regulator isn't damaged. If its not, then you should just be able to pop the window back on and go. Otherwise you'll have to do some surgery to fix or replace the regulator. Good luck...
wileec
Sep 11, 2015 10:16 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 8, 2015 11:50 AM
amandahchase
Sep 3, 2015 10:09 AM
