First time pulling engine
Old Apr 28, 2010 | 06:49 PM
89GTnoob's Avatar
89GTnoob
Default First time pulling engine
I'm a DIY mechanic in training (the internet is teaching me lol). My starter doesn't want to catch the flywheel. I can take a wrench and turn over the motor a few inches and the starter will find a good spot and start the car. How hard would it be for a first timer with basic knowledge to pull my 5.0 motor and replace the flywheel using basic tools (engine hoist, jack stands, etc.)
Old Apr 28, 2010 | 07:37 PM
a_penquin's Avatar
a_penquin
label everything!!!!!!!!!!!!!! wires, hoses, everything!!!! Otherwise its a couple bolts and a lift away. My best advice to you would to be to drop the trans instead. The flywheel/flex plate will still be easily accessible and a lot less work and possible issues in the end. If you have a manual I would highly recommend replacing the throw out bearing, and possibly clutch at the same time. Just to make sure your not doing the work again a few months later.
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
mweiland
Aug 13, 2015 05:11 PM
