ECU/Smog Issue *help!*
Old May 3, 2010 | 02:36 PM
GiggleFitTrishy's Avatar
GiggleFitTrishy
Default ECU/Smog Issue *help!*
Hi guys, HELP! I'm trying to smog my 2000 Mustang. It passes visual and emissions fantastically, but fails the MIL Check Engine Light part of the test. Apparently, my ECU resets constantly. I've run it through countless drive cycles and still, ECU does not retain memory. I'm going to replace the battery cables, hoping that because the cables are somewhat corroded, that may have something to do with it (?). I can't find OEM cables, does it matter? Any other ideas of what may be causing my ECU to erase memory like this?
Old May 3, 2010 | 03:28 PM
a_penquin's Avatar
a_penquin
sounds like a fault in the ECU
Old May 3, 2010 | 04:34 PM
GiggleFitTrishy
Thanks, you're probably right. Was hoping it was an easier fix. =/
Old May 3, 2010 | 05:23 PM
a_penquin's Avatar
a_penquin
Looks like you can get one through ebay for about $95. You could also move to a state that dosent do emissions and never have to deal with it again
Old May 3, 2010 | 06:34 PM
GiggleFitTrishy
haha, wish I could move!! Thanks for your help, never thought to look on ebay!
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
