Cams for an 02 GT
Old Aug 5, 2005 | 12:29 AM
ghoste's Avatar
ghoste
Default RE: Cams for an 02 GT
ORIGINAL: Fat Nick
ORIGINAL: ghoste
I know that
Im asking "If valve springs werent purchased, would this do any harm? " with stage 2 cams.
So if the company that makes them tells them you need something you're going to overlook it?
Yes, they need springs because like said above, stg.2's are meant to go to 6500 which isn't smart on stock springs.
So yes, get the springs, or you'll regret it later.
Computer upgrade means chip and dynotuned. Stg.1 requires no spring and no tune. Although a tune will get you a few more ponies. My advice is that with the auto if it's a daily driver get the stg.1's. The stg 2's only make more power than the 1's at 6000-6500. Which on an auto would go to high and not take full capability of the powerband.
They never noted I "Needed" them, they said "Recommended". This is why I asked.
For Stage 2, It requires 2400+ stall, and 3.55+ gears. Intake, Exhaust, Computer Upgrade, and Spring Recommended.
..and thank you for the explaination between stg1 & stg2 performance wise.
Old Aug 5, 2005 | 06:19 PM
Fat Nick's Avatar
Fat Nick
I ♥ Acer
You will also need the stall because the idle below 2k will be garbage.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
