How traction control works?
Old Aug 4, 2005 | 07:42 PM
99saleen351r's Avatar
99saleen351r
Default RE: How traction control works?
No.... because it pulls timing too so it doesnt hurt anything having less fuel.I had mine shut off also,you definatley dont want that working with high HP.Ever try to drive in the snow with that???Its a riot the car cant even move cause as soon as it spins it puts the brakes on and gets all screwed up.Half the time you cant even move with it on
Old Aug 4, 2005 | 11:13 PM
4600cc's Avatar
4600cc
I ♥ Acer
ORIGINAL: sandcracker21
TC has almost killed me a countless number of times
Oh dude! I have TC on my new stang, and I'm loving it. Previously I had a vic without TC, open rear, no ABS, and no variable steering. No TC got me spinning at 120, open rear got me sideways, no variable steering got me over correcting, no ABS got me sliding into a freaking wall. You gotta have a TC! Trust me.
AL
Old Aug 4, 2005 | 11:22 PM
4600cc's Avatar
4600cc
I ♥ Acer
ORIGINAL: 99saleen351r
The reason I'm asking because I want custom EFI and ignition controller, but I also want to keep TC, ABS, air bags, and guages. For ignition I prefer megajolt, www.picasso.org . Latest program has a soft rev limiter which retards timing to 0 before reaching hard rev limiter. For EFI I want megasquirt II, www.megasquirt.info . These two are superior in some ways to Emerald, www.emeraldm3d.com . Of course they don't just bolt on, you'd have to make everything work with ECC-V, which I'm not familiar with yet.
AL
Old Aug 4, 2005 | 11:54 PM
F1rocco's Avatar
F1rocco
it doesnt matter how it works.....the fact is.....IT DOESNT WORK
ACOPYANDPASTE
It's natural to assume that traction control will be simple to implement and will reduce the gap between the front and back of the grid. However, traction control opens an entire world of active car control that may increase the performance difference between "haves" and "have-nots."
Traction control isn't limited to preventing wheel spin during acceleration. It allows traction at the rear wheels to be actively controlled by the drivetrain at anytime. This control can be used to influence any aspect of a car's performance, including braking and cornering. Control of rear wheel traction may not be an engineer's first choice to influence braking or cornering, but it certainly suffices.
This comprehensive traction control requires a complex algorithm. Teams will program traction control computers with the car's desired behavior for any situation. Sensors on the car will tell the traction control computer what the car's behavior actually is. The computer will then use mathematical models of the drivetrain and vehicle dynamics to determine what drivetrain actions should be taken to make actual car behavior most closely match desired car behavior. Closed loop feedback can be used to fine tune any part of this algorithm while the car is being driven.
The mathematical drivetrain model is needed to predict the throttle, ignition, and fuel required to produce a desired torque at the rear wheels. This model would include engine torque for any RPM, engine temperature, air pressure, etc. Furthermore, this torque can be negative (braking torque). The model would also include things like engine rotational inertia, gear ratios, and driveshaft torsional stiffness.
The mathematical vehicle dynamics model is needed to predict the rear wheel torque required to produce a desired behavior on the track. This model would include things like aerodynamic forces, masses, moments of inertia, tire information, and suspension positions. The vehicle dynamics model would be improved with track mapping to including bumps, hills, corners, and other influences on car behavior.
The models help traction control get from current behavior to desired behavior, but what is the desired behavior?
During braking the car will effectively have active rear brake control. If there is too little rear brake force then the drivetrain can put negative torque into the rear wheels to compliment the brakes. If there is too much rear brake force then the drivetrain can put positive torque into the rear wheels to partially counteract the brakes. The driver will have quicker braking and less concern of locking the rear end and spinning going into a turn.
In a steady state corner, if a driver responds to oversteer by lifting, then lift-throttle oversteer can make the situation worse. Traction control can use the vehicle dynamics model to predict how quickly the throttle can be rolled off without making the oversteer worse. Traction control can then override the driver until it determines that the car would be stable again under driver control. Traction control can also sense or predict oversteer on its own and gently roll off the throttle without any input from the driver.
Traction control isn't even simple during acceleration. A tire turning at ground speed creates no forward force, so the tire must slip slightly to accelerate the car. The acceleration increases with slip until it peaks (typically at 20% slip for street tires) and then decreases with additional slip beyond this. By contrast, tire wear doesn't reach a similar peak and always increases with more slip.
A good driver without traction control can keep acceleration near peak, but generally errs on the side of less slip and less wear. Well executed traction control can keep acceleration closer to ideal than any driver but, contrary to intuition, traction control's greater slip can also increase wear. During qualifying a team might choose to maximize grip at the expense of wear and then change the tradeoff for the race.
So far only pure braking, cornering, and acceleration have been considered. However, an F1 car will often be in complex combinations of these situations. What does the traction control system do to maximize performance in these instances? How should traction control influence the car so the driver still has confidence the car will response like he wants? Think traction control is still simple? Maximizing the potential of traction control will be the work of entire departments of engineers.
This complexity will be a long-term challenge for Ferrari and McLaren. At the other end of the pitlane Minardi is fighting to survive, and any notion of additional engineers to work on traction control is quixotic. Crude systems that merely prevent excessive wheelspin during acceleration are easy to make, so the entire grid will have various forms of traction control once it's legalized. They will likely get what they pay for. However, all teams want traction control at some point in the future despite its burdens. This is a strong indication of how frustrated the teams have become with the potential cheating that legalized traction control seeks to avoid.
Nurdyguy
Jan 20, 2025 04:38 PM
squishbang
Dec 4, 2015 02:29 PM
iculookin
Sep 2, 2015 12:34 PM
Sep 1, 2015 08:16 PM
Mustangdanny
Aug 10, 2015 09:34 PM
