MSD cap on dizzy, where's #1?
Old May 18, 2010 | 05:04 PM
89GTnoob's Avatar
89GTnoob
Default MSD cap on dizzy, where's #1?
Can someone point out where #1 is on this MSD cap (didn't want to remove wires and lose my firing order since that's what I'm checking). I believe the very top wire is going to my #1 currently, but I have no idea if that is correct. You can see the plug for the distributor at the bottom of the pic to give you an orientation of the distributor.
Old May 18, 2010 | 06:24 PM
GreyStang's Avatar
GreyStang
Why don't U follow the spark plug wire from #1 piston, which is the front one on the passenger side..
Old May 18, 2010 | 07:32 PM
89GTnoob's Avatar
89GTnoob
I wasn't sure #1 was right on the dizzy. It's good though, I had enough of the original firing order hooked up correctly to figure out that I had 2 and 4 swapped. Thanks for the help anyway. I was hoping the MSD cap only fit on one way and had a marking for the number 1 plug on it.
firehorse02
Nov 16, 2015 11:28 AM
piotrek53
Oct 13, 2015 06:54 PM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Dathan
Oct 5, 2015 05:52 AM
Wombatnation
Sep 13, 2015 09:16 PM
