Welding Practice
Old Jun 11, 2010 | 08:42 AM
  #31
mapitts's Avatar
mapitts
Had a little time here so I thought I jump back on and comment on the subject of weld ripples. Unless you are using a 6010 or 6011 stick electrode or aluminum MIG. You should have no steps in your weld. Even using MIG gas shielded or inner shielded (flux cored) wire. The main reasons are cold lap and slag inclusion. If you are using gas shielded wire and are stepping the puddle out far enough that you are leaving your puddle behind, you stand a very good chance of either leaving silicone in your step back or cold lapping it. Don't believe it? Take a butt weld plate test. Step your weld and then grind it. Now you can x ray it and you will see little "c's" or little "j's" in the x ray. Or you can grind it and do a root bend / face bend test. Or you can just clean the weld with a wire brush and do a die penetrant test on it. See what you end up with. You should use the same technique when you use MIG or stick electrode. I know a lot of people will argue, but there is no telling how many tests I have taken over the years. You can even fail a welding test by grinding the weld the wrong way.
Old Jun 11, 2010 | 02:08 PM
  #32
mstngsule68's Avatar
mstngsule68
im not going to argue, but lets just say i have passed the structural certification test. you are not the only one around the block here.... why dont you stop setting here being mr. know-it-all, you arn't impressing anyone.
Old Jun 12, 2010 | 11:30 AM
  #33
Gregski's Avatar
Gregski
Default How Hard Coult It Be
it's the fifth and final episode of the "How Hard Could It Be" Welding Boot Camp, with special features:
Wardrobe Makeover
A Solution Looking For a Problem
Like a Pro, but different...
ADVICE FROM A NEWBIE:
From my minimal experience I can tell you that it is better to weld for one hour each day for five days than it is to go out and weld for 5 hours in one day. Ideally with a day or two in between. You will find that you have some good days and some bad days. During the summer time it will be hot, and you most likely will be wearing heavy denim jeans and a long sleeve shirt and or jacket, and a black helmet and leather gloves. It will be hot and at times uncomfortable. Remember you are only competing against yourself, each day you are trying to get better than yesterday, so don't over do it.
more at http://gregandsandy.com/302/welding5.htm
Old Jun 13, 2010 | 11:44 PM
  #34
mstngsule68
your weld pushing it had about 60% decent weld, for to push it, you need to set your wire speed to your speed, and you just naturaly have the correct fill going in.... google the "push pull method"...
Old Jun 14, 2010 | 10:51 AM
  #35
mapitts's Avatar
mapitts
Sorry, I did not realize that you were this forum's sole welder. Don't get all balled up in a knot because someone has a different theory than yours. I will take my 20 year Journeyman's card, set back and let you lead class.......
Old Jun 14, 2010 | 12:11 PM
  #36
mstngsule68
a different theory is one, trying to act like a know it all is different.
Old Jun 14, 2010 | 07:15 PM
  #37
Gregski's Avatar
Gregski
That's it how many of you wanna see a mstngsule68 and mapitts weld off ?
Gentlemen submit some samples of your work, cause maybe you're both right!
... and don't make me come over there, LOL, jk
Old Jun 14, 2010 | 09:53 PM
  #38
mstngsule68
i have a spool of flux core .035" wire, ill throw it in my 110v... set it up the same.
Old Jun 15, 2010 | 12:01 AM
  #39
Gregski's Avatar
Gregski
you're a good sport
Old Jun 15, 2010 | 12:15 AM
  #40
mstngsule68
ill even let him pick the weld position
