Stange clutch grating sound
Old Aug 6, 2005 | 02:07 AM
cdrj's Avatar
cdrj
Default Stange clutch grating sound
Hello, I have a question for you guys. My car is a 2001 v6 manual with about 55k miles on it. I have had the transmission completely replaced (new T/O bearing, new clutch, pressure plate, flywheel, new clutch cable, new piece that the throwout bearing rides on). Anyway, after all of this, I still have a strange noise coming from my clutch as I am depressing it at higher (about 2500+) rpms. It sounds like a grating or growling metal on metal type sound, almost like something scraping. I can "feel" this sound as well as I am pressing the clutch. This only happens at those rpms, and is extremely annoying (to me at least). Anyway, I was just wondering if this has happened to anyone else, or if maybe someone knows what the problem is. I would like to have it fixed not only for cosmetic reasons, but I am also worried that it might be hurting my car.
Thanks for the help guys, any reply is really appreciated.
Ryan
Old Aug 6, 2005 | 02:52 PM
lookin4stang's Avatar
lookin4stang
Default RE: Stange clutch grating sound
i used to have a camaro and shortly i had the clutch replaced i had that same noise. i checked the tranny fluid and it was bone dry. you might want to check the fluid
Old Aug 6, 2005 | 03:28 PM
99saleen351r's Avatar
99saleen351r
Are you sure the clutch is in right and not backwards or something??There isnt much that could make that noise unless its metal on metal
Old Aug 6, 2005 | 04:24 PM
cdrj's Avatar
cdrj
Yeah, pretty sure its in right. It was professionally installed twice (the second time was to replace the components of the clutch kit to make sure there were no bad parts).
I'm not sure how to check the tranny fluid, does anyone know how? Also, does a cable driven clutch even have tranny fluid, or is that only for hydraulics? Thanks for the help guys, if I could just pour some fluid in there, that would be a heck of a lot better than having to rip the whole thing apart again.
Ryan
Old Aug 6, 2005 | 04:43 PM
99saleen351r
On the side of the tranny there is a plug that fits a half inch ratchet in it remove that and stick your finger in it if you can touch the fluid its fine if you cant you have to squeeze the fluid in threw that little hole.Its kinda a pain in the neck on the ground but it can be done with a tube on the end of the bottle.And yes the tranny has fluid put the clutch does not if its a cable,only hydraulic clutches have fluid
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Emblazoned
Sep 3, 2015 10:45 PM
kawiguy827
Sep 1, 2015 07:09 PM
