Radio Help
Old Jul 3, 2010 | 09:44 PM
Levi Simonson's Avatar
Levi Simonson
Default Radio Help
So I got this 97 ford mustang v6 used and recently found out the factory rear 6x9 speakers were missing and the wire dangling from the trunk. I went and got some and tried to plug them in but low and behold the speakers didn't work. So I tried using a multimeter to see if there was even any power going through. There wasn't. And now I am stuck at a predicament where the wires that go to the back of the radio don't even match the ones in the user's manual. So would anyone have an idea which wires are what on that back of this connector. Thank you for anyone figures this mess out for me.
Old Jul 4, 2010 | 08:50 AM
MOOK3456's Avatar
MOOK3456
Easiest fix imo, just run new wire along the kick panels/around back seat. Before you do though I'd test the leads at the head unit. It may not just be the wires.
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black/Green
Illumination Light Blue/Red
Dimmer n/a
Front Speakers
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
Old Jul 4, 2010 | 02:18 PM
GreyStang's Avatar
GreyStang
You can test the leads by the head unit using a little 9volt battery. Just touch the wires to each connector and you'll hear that corresponding speaker "crackle" a bit.
Does your head unit support front/rear speakers? Is there a front/rear fader control on it?
Old Jul 5, 2010 | 02:41 PM
Levi Simonson
Yes it does have a front/rear fader. And Mook you just gave the same wiring schematics as what the manual says. They don't match up. Only light blue wire on that connector is got a red stripe not a gray one. I am pretty sure there is no power running to the wires that are in the back, but I don't exactly know which wires lead to the back of the radio to find out lol.
Old Jul 5, 2010 | 02:43 PM
Levi Simonson
as for running wire along the kickpanel to head unit i need to know which wires in the head unit control the back speakers.....since the diagrams aren't matching what's back there it's quite a mystery. Any help would be appreciated
Old Jul 5, 2010 | 02:44 PM
Levi Simonson
Greystang, will that method work with the battery unplugged or does it have to be attached?
Old Jul 5, 2010 | 02:49 PM
GreyStang's Avatar
GreyStang
It doesn't matter if the car battery is connected or not.. the speaker wiring doesn't get affected by that. But still, if it makes you more comfortable then disconnect that battery.
Like I said, whenever you hit a lead with the 9v battery to any speaker you'll hear that speaker crackle a little bit. It won't do any damage but it will help identify the wiring.
Old Jul 5, 2010 | 10:38 PM
MOOK3456's Avatar
MOOK3456
Cut the grey wire wrap on the other two connectors lengthwise with a razor and you should find them.
The wires that are now visible to you on the open harness are power/ground and they are just what I posted-
Ground Black/Green
Dimmer n/a
One of those wrapped bundles holds-
Front Speakers
and the other holds-
Rear Speakers
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
vbonina
Sep 22, 2015 08:31 AM
Gkid182
Sep 22, 2015 08:17 AM
unit91
Sep 15, 2015 09:53 AM
