low speed vibration
Old Aug 9, 2005 | 03:22 PM
midlifemustang's Avatar
midlifemustang
Default low speed vibration
This past weekend I purchased a 1999 Mustang with a 3.8l and automatic with 80,000 miles. When I test drove the car I could tell that there was a vibration that felt like driving over rumble strips. At approx. 35 MPH the car would smoothe out quite well. I figured that there was a tire issue so I used this a a bargaining tool with the dealer.
I've taken the car to several tire shops, all say that the tires are fine. One guy suggests that the vibration is coming from the drivetrain. A dealer is suppose to check it out this afternoon.When I ask them they seem lost. Have any of you experienced a vibration problem like this? How well does the transmissions hold up on these cars? Any suggestions?
Thanks
Frank
Old Aug 9, 2005 | 03:56 PM
92hatchLX's Avatar
92hatchLX
Default RE: low speed vibration
I've heard of the 3.8's taking a **** on you after 100,000 miles. If it was tires it would worsen as you accelerate. Sounds like a drive train issue.
Old Aug 9, 2005 | 04:18 PM
stngman00's Avatar
stngman00
I have a 00 Automatic V6 and mine does the same thing at around those speeds, and then like you said it smoothes out and stops. So let me know what happens after it get's checked out.
Mike
Old Aug 9, 2005 | 07:52 PM
midlifemustang
The dealer says that the bushing in the tail shaft housing is worn out. I guess that this has been going on for quite a while because it has damaged the housing. Anyway, this is allowing the driveshaft to flop around. Replacing the housing, bushing and seal, $250.00. It will be repaired by tomorrow evening. I'm pleased with that.
Later, and thanks,
Frank
Old Aug 10, 2005 | 12:40 AM
Leadfoot's Avatar
Leadfoot
Hi! I am from Warner Robins as well. I have been looking for a car for my daughter and was wondering which dealership you purchased your vehicle. I have been avoiding used car lots because they can be so underhanded and over pricing their vehicles.
Anyway, are you happy with whom you worked with?
Old Aug 10, 2005 | 03:43 PM
midlifemustang
Hey Leadfoot,
I purchased the car from a used car dealer on Watson Blvd. The name of the business is "Route 66" and this is the first dealings I've had with them. It's mom and pop start up operation, no pressure and very good prices. I have no other business affillation with them.
Later
Frank
Old Aug 11, 2005 | 04:32 PM
Deannostang's Avatar
Deannostang
Ledfoot, check out this link for hundreds of certified, dealer owned Mustang V6's:
http://autotrader.com/fyc/searchresu...&sponsorModel=
I used my zip of 12207. You can modify search with your zip and get best deals close to your location. Good luck!
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
movielover40
Sep 15, 2015 10:37 AM
