WHINE
Old Aug 11, 2005 | 11:23 AM
pauldut's Avatar
pauldut
Default WHINE
HAVE A 1999 GT AND HAVE STARTED HEARING A WHINE COMING FROM THE REAR AREA.HAVE 620000 MILES
Old Aug 11, 2005 | 12:13 PM
02StanGT's Avatar
02StanGT
Default RE: WHINE
ORIGINAL: pauldut
I'm assuming you meant 62,000 miles. Anyways sounds like your rear gears. Does the noise get louder in relation to your speed? Have you had gears installed?
Old Aug 11, 2005 | 04:05 PM
Deannostang's Avatar
Deannostang
Default RE: WHINE
At 620,000 miles you should hear alot of whining. I know you didn't mean it, 62,000 more likely. Have someone check your rearend fluid for proper level and/or just replace it with one of the premium synthetic rearend lubes out there. Royal Purple, Redline, Amsoil just to name a few. Your gears should run and sound much better after the change. If a bad whine still persists after a few days of running the car with its new rearend fluid, then possible mechanical repair may be necessary. It may just be low or has run its course due to your driving style. I'd vote for a full fluid change myself. Good luck!
Check this out: http://www.royalpurple.com/prodsa/mgeara.html
Old Aug 11, 2005 | 04:40 PM
sandcracker21's Avatar
sandcracker21
Default RE: WHINE
while ur down there, why not get sum racing gears?
maybe a good 4.10 ratio
KingRando
Oct 1, 2015 11:16 AM
FivePointToTheOh
Sep 29, 2015 12:53 PM
Beerman309
Sep 19, 2015 01:16 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
91StangOwner
Aug 20, 2015 11:34 PM
