windstar intake kit
Old Sep 21, 2010 | 06:43 PM
alfred9744's Avatar
alfred9744
Cool windstar intake kit
just got an o1 v6 conv.for a dd this way i can let my 70 ranchero b a weekend driver.my question is what parts do u use from the windstar,and what r the bennys,guess i am used to carbs and point ignition systems,so any feedback on some mild mods is appreciated
Old Sep 21, 2010 | 06:53 PM
LilRoush's Avatar
LilRoush
You need everything from the air filter to the intake itself. There are a couple of thread in the V6 section about the swap that might help you out.
It's one of the best flowing factory Ford intakes for that motor.
Old Sep 21, 2010 | 07:00 PM
Synyster06Gates's Avatar
Synyster06Gates
# Modified Windstar Intake w/Bolts & Gaskets
- Cut and Filled IAC Port
- Added IAC outlet
# Modified 3.8 Mustang Throttle Body
- Throttle/Cruise Bracket Extension
- Throttle Cable Bracket Extension
# IAC Valve Relocation Bracket
# Fel-Pro IAC Gasket
# 2x Fel-Pro TB Gaskets
# Coil pack / Throttle bracket
- Fits both 99-00 and 01-04
- Powder coated gloss black
# 3" Mandrel Bent Intake Tubing
- Powder coated mirror black
# 3" Rubber 90 degree coupling w/clamps
# MAF to Air Filter adapter
# New Angled Throttle Body Spacer
# Low profile EGR mount
# 2x Fel-Pro EGR Gaskets (not pictured)
# EGR Sensor Bracket
# Bolts, Nuts, Hose Clamps
# Vacuum Hoses & Tee's
# Wire and Wire Splices to extend sensor connections
http://www.vapauto.com/windstar_full.htm
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
04stangman
Sep 17, 2015 01:45 PM
ernesto-619
Sep 10, 2015 01:32 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
