trans swap
Old Dec 29, 2010 | 07:28 PM
Joe Giammona's Avatar
Joe Giammona
Default trans swap
I have read that i can swap my 92 mustang t5 trans for a t56. I have read that it will bolt up with no problem to my existing bell housing. Currently i am in the process of replacing the syncro's in the transmission but since ive got it all apart i figured why not play with it a little bit.
My question is, well if i swap to 3.73 gears and replace the spline and switch to a stage 3 ford racing clutch while also changing the tooth size on my flywheel, will all of this mesh as well as i think it will. What im not sure of is the power glide from the chevy transmission
Old Dec 29, 2010 | 09:13 PM
enix187's Avatar
enix187
I'm sorry but what did you say/ask, organize your thoughts man because they deffinitely don't make any sense the way you just put them on here.
Old Dec 30, 2010 | 02:22 AM
Joe Giammona
If i switch to the t56 trans from a chevy (which is a powerglide), will i be able to run a lower tooth flywheel and larger spline.
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
2poor4u2
Sep 26, 2015 11:08 AM
