Busted ball joint
I had my drive side ball joint separate and come out of the boot so I took the control arm off and pressed out the old ball joint and put a new one in. After that I went to remove the actual ball off of the spindle since I had to let it soak in some rust breaker but i good not get the nut off no matter the size of the breaker bar. So I cut the nut off and figured the ball would come out but it didn't move. I beat it with many different size hammers and it doesn't seem to budge. Are the actual ***** pressed into the spindle , are they screwed in, or is it the 9 years of Chicago weather that is just binding it?
All ball joints are pressed in from factory. You really gota beat on it until it comes out. Now I actually recommend you to take the new ball joint and have it pressed in at the shop. You can do it yourself with like a 30 MM socket and a nice hammer to get it back in there. I did it on mine just be careful
yea i already got the ball joint piece out of the control and had a new one pressed in. My problem is that when it broke the actual ball part of the joint is still stuck on the spindle and i can not beat it out for the life of me. Just wondering if there were any tricks to getting the piece out or just beat it into submission
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
