Noob that needs help!!
Old Jan 29, 2011 | 07:07 PM
ns99gt's Avatar
ns99gt
Default Noob that needs help!!
Hi their my name is nick from jersey and I have come to the point in my mods where I have no idea where to go .. My ride and set up are as followed
1999 Mustang GT 35 Anni. Edition Convertable 5spd
Trick Flow 38cc track heat heads with comp stage 2 cams
Stock injectors and pump
Stock TB/plenum ... 75mm Trick Flow TB/Plenum in the mail
American muscle CAI
Pypes long tube headers
BBk catted xpipe
Bassani Bx catback
Stock clutch
Stock gears
No tune yet still waiting on some parts
Maybe nitrous later on
What I dont know is if my fuel system can Handel a full Bolt-on head and cam 4.6 ??? What is the stock pump and 19lb injectors good for and if I need to upgrade what do I need to get .. Also with plans of running nitrous later on this further compounds the fuel concerns that I have, because I don't want it to run lean and take a dump on me ... If any body could help me out it would be grately appricated !!! Thanks nick
Old Jan 29, 2011 | 07:21 PM
mrtstang's Avatar
mrtstang
Welcome! I'm pretty sure the 19lb injectors will be at their very limit with your setup. The pump should be okay. How big of a shot do you want to run? Wet or dry?
Old Jan 29, 2011 | 07:34 PM
ns99gt's Avatar
ns99gt
75-100 wet ZEX depending in what the N/A #s come out to... dou you think i should go uo to the 24lb or 30lb injectors
Old Jan 29, 2011 | 07:45 PM
mrtstang's Avatar
mrtstang
IMO, i would do at least 30's. I run 42's just so i have room to grow. Also my fuel pump was good to around 360 rwhp on the juice. You don't have forged internals right?
BTW, i see that you have stock gears. You have plans to change them?
Old Jan 29, 2011 | 07:51 PM
ns99gt's Avatar
ns99gt
yup bone stock bottom end, as for the gears its either 4:10s or 3:73 ... i was planning on the 4:10s but i didn't know if the would be to tall with the spray
Old Jan 29, 2011 | 07:52 PM
ns99gt's Avatar
ns99gt
and i just found the 3:90s the other day sooooo idk hah
Old Jan 29, 2011 | 08:07 PM
mrtstang's Avatar
mrtstang
Well, i guess that would depend on how far you will be able to rev out.
Emblazoned
Sep 3, 2015 10:45 PM
akm2k5
Feb 14, 2005 09:13 PM
Justanother5.0
Nov 28, 2004 12:58 AM
Natex
Apr 10, 2004 02:39 AM
fromslow2fast
Feb 16, 2004 03:20 AM
