Edelbrock vs Holley
Old Mar 10, 2011 | 06:13 AM
cobra3338's Avatar
cobra3338
Default Edelbrock vs Holley
Iv always been told holley carbs are better than elelbrocks but wanted some opinions on the subject. the motor is a 393w making around 390rwhp with an edelbrock performer 750cfm carb
Old Mar 10, 2011 | 11:26 AM
GreyStang's Avatar
GreyStang
Don't forget Predator!
Old Mar 10, 2011 | 05:13 PM
67mustang302's Avatar
67mustang302
Edelbrocks require less wrench turning to tune(metering rod changes are faster than jet changes), they're reliable, good for daily drivers. But, they all suffer from the inherent Carter AFB design flaws, primarily a weak accelerator circuit, so they suffer throttle response problems. They also use older technology in regards to boosters and metering systems.
Holleys on the other hand require more wrench turning to tune, but modern Holley designs use much better booster and metering tech, and with double pumpers you can get break neck throttle response. And with the use of more advanced metering blocks, the emulsion packages can be tuned to a specific vehicle.
A modern double pumper Holley type carb with annular boosters and a custom metering system will blow an Edelbrock carb out of the water in terms of performance every time.
Predators are meh, if you want a real single barrel, look at the new Pro Systems SV1. It's new within the last few years.
Old Mar 11, 2011 | 09:26 AM
cobra3338's Avatar
cobra3338
ok thats what i thought, do you think a holley would make more power with similar cfm?
Old Mar 11, 2011 | 01:29 PM
67mustang302
They usually do, if you get a good one.
Old Mar 12, 2011 | 02:02 AM
DeltaElite121's Avatar
DeltaElite121
If you're going to spend that kind of money on a decent 393 rotating assembling, you're doing yourself a disservice by going short on the carb. Holley and Holley-based carbs are the way to go. There's a reason a majority of dragracers use them. Get yourself a nice AED/Prosystems/Quickfuel/Proform and never look back.
Old Mar 17, 2011 | 12:29 AM
cobra3338's Avatar
cobra3338
speaking of the rotating assembly how much hp do you think the bottom can handle its got Eagle Cast Steel Crankshaft with 4.00 Stroke, Eagle I-Beam Connecting Rods with ARP Bolts & Bushed Pins, and SRP Performance Flat Top Pistons with Coated Skirts?
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
LiquidDrink
Sep 29, 2015 10:06 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
Wombatnation
Sep 13, 2015 09:16 PM
tramphardrocker
Sep 13, 2015 08:56 PM
