94 mustang gt issues help
Old Mar 16, 2011 | 08:55 PM
tsrracing's Avatar
tsrracing
Default 94 mustang gt issues help
I bought a 94 mustang gt that I need help with. The car runs rough and has a power loss. It acts like it is miss firing and smokes black when u crack the throttle. It has bbk headers and not sure on exhaust. Did a test and came up with these codes 136 ho2s sensor fault always lean. 172 ho2s sensor fault/lean. There is no o2 sensors in the headers. The person B 4 me put metal plugs in them. I found one o2 plug harness on the passenger side but not one on left. Is there one or two o2 sensors on the car. I need help to get this going.
Old Mar 17, 2011 | 12:15 PM
SNV425's Avatar
SNV425
first step is to fix the codes. put the 02 sensor back in the exhaust and start from there. get a service manual. good luck.
Old Mar 17, 2011 | 02:54 PM
ryan1994mustang's Avatar
ryan1994mustang
there arent supposed to be any O2 sensors in the headers. There should be an O2 sensor in each side of the h-pipe, just before the first set of cats. if you dont have these O2 sensors in, the car is going to run super rough and try and compensate for the Air/Fuel Mixture that it is receiving (which is wrong because of no sensor).
Old Mar 19, 2011 | 09:19 PM
tsrracing's Avatar
tsrracing
Default 94 mustang gt help
I looked the only two areas for the o2 sensors r in the exhaust pipes right under where the headers and exhaust hooks up. There is a plug there where the o would hook up. There is no plug for the left side. looked every where.
Old Mar 19, 2011 | 09:21 PM
tsrracing's Avatar
tsrracing
djbigskrilla
Sep 20, 2022 01:04 AM
cyclop5
Oct 3, 2015 09:21 PM
mweiland
Aug 13, 2015 05:11 PM
'stangdude
Aug 12, 2015 01:27 PM
daytooday
Aug 11, 2015 09:22 AM
