How I should go about upping octane
Old Mar 21, 2011 | 10:04 AM
SilverStallion05's Avatar
SilverStallion05
Newer engines (like yours) can retune itself to work safely with whatever octane you put it in. You engine will not tune itself to accept the performance benefits of the higher octane, but it is safe to put a higher octane in at any point before the tune.
Of course... It is always better to have it tuned.
Old Mar 21, 2011 | 09:50 PM
AMChrisRose's Avatar
AMChrisRose
Just be careful that any additives you use are not leaded.
DreamerGT has some great suggestions for Injector cleaner on the last page. I also really like the Lucas stuff as well.
Old Mar 22, 2011 | 12:35 PM
mustangfan06's Avatar
mustangfan06
IP Match to scammer
You can use leaded if you dont have cats
Old Mar 22, 2011 | 02:52 PM
AMChrisRose
Lead and your front o2 sensors aren't best friends.
Old Mar 22, 2011 | 02:56 PM
aerbourne's Avatar
aerbourne
thanks guys, ive actually driven more than i thought i would so i am probably just going to wait till im pretty low and fill up with 91 or 93
Old Mar 22, 2011 | 04:25 PM
GreyStang's Avatar
GreyStang
You know having octane that's "too low" isn't really harmful unless you're revving the snot out of the engine. Loping along in traffic U can run regular pump grade no problem.
Old Mar 22, 2011 | 08:23 PM
AMChrisRose
Correct. We ran 89 octane on a 800+RWHP GT500 that normally takes C16 because we absolutely had to one time. It's fine, as long as you don't operate the car under heavy load.
Chris
Old Mar 22, 2011 | 10:54 PM
sonicx's Avatar
sonicx
speed'n
Originally Posted by DreamerGT
If you get something for the fuel system, get something that has an PEA base. Like Redline SI-1 or Amsoil PI, Techron Concentrate, and Gumout with Regane to name a few. That should help clean the injectors and valves and anything else it touches.
So adding those wont eat anything away internally or cuz gunked up? Just wanting to make sure. Thanks again for the help.
Old Mar 23, 2011 | 09:47 AM
mustangfan06
IP Match to scammer
Interesting I did not leaded gas bad for o2 sensors always heard it was actually good the engine and good for cars without cats
McLeary
Mar 14, 2016 07:50 PM
Big Al's 03
Sep 15, 2015 09:05 AM
MasterLanMan
Sep 13, 2015 08:21 PM
Sandmanbjj
Aug 21, 2015 12:38 PM
