Horrible Shaking
Old Jul 3, 2011 | 12:11 PM
Xunaria's Avatar
Xunaria
Exclamation Horrible Shaking
2001 Mustang V6 all stock I just bought is shaking and jerking bad at Idle and up to around 20 MPH then it seems to run smooth, the car doesn't seem to have a lot of power but im assuming its because its the V6. Any idea's what would cause the jerking? Im thinking spark plugs or fuel pump/filter but im kinda new at this. Thanks
Old Jul 3, 2011 | 02:27 PM
DJ19895.0's Avatar
DJ19895.0
Is it missing? Put your hand over the exhaust pipe and it should feel relatively smooth and consistant, if it is not it is probably missing. Replace the plugs (wires too if they look old) and it it continues preform a cylinder balance test. Pull one injector off at a time, and the one that did not make it run worse is your bad cylinder (probably bad injector or wiring)
Old Jul 3, 2011 | 05:41 PM
scottybaccus's Avatar
scottybaccus
Does it shake sitting still, or only when moving? Sitting is a missing cyclinder, rolling could be wheel/tire issue.
Old Jul 4, 2011 | 05:40 AM
Xunaria's Avatar
Xunaria
I guess the right term is bucking, like someone keeps bumpin into the back of the car throwing me personally back and forth, does it while sitting still and driving at low speeds, up to about 20 mph then it seems to go away until. Stop at another light or slow down for traffic
Old Jul 4, 2011 | 05:43 AM
Xunaria's Avatar
Xunaria
Then it comes back, hit post too soon lol
Old Jul 4, 2011 | 12:27 PM
scottybaccus
Sounds like you probably have a miss that needs to be resolved, probably plus and wires, etc.
It's also possible that you have a broken motor or transmission mount that is exagerating the effects. Check all of your isolators for tears and tune it up.
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Nov 18, 2015 01:34 PM
GLOCKer
Sep 28, 2015 07:36 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
