P0340 Code with freshly installed cams and e-force HELP!!!!
Old Jul 11, 2011 | 04:18 AM
Undead Pony's Avatar
Undead Pony
Exclamation P0340 Code with freshly installed cams and e-force HELP!!!!
I purchased and installed the Detroit Rockers for supercharged applications and the stage 1 Edlebrock E-force from Brenspeed. Everything seems to be working fine but I keep getting the trouble code P0340 and sometimes when I put the car in R the RPMs drop and the car dies. I have looked around at other posts but I don't know if you can apply them to my situation since most were non cammed/supercharged. So far I have checked the connecters, taken off the cam sensors, cleaned, reinstalled and have returned the tune to stock then re-loaded it. Once the code is cleared I can drive around without it coming back on until the next time I start it up. I personally don't believe my alternator is going out, I've never had this problem in the past.
Please help I'm out of ideas.
Old Jul 11, 2011 | 04:29 AM
Undead Pony
Also thought I solved this problem but it keeps coming back and I'm not sure if it may be related or not but now when I start the car it shoots up to 3000 RPMs then goes all the way down and dies.
Old Jul 11, 2011 | 12:24 PM
JIM5.0's Avatar
JIM5.0
Have you tried to talk to Brenspeed? Maybe they can fix the issue with just an adjustment in the tune.
Old Dec 28, 2011 | 11:48 AM
aa4shaw's Avatar
aa4shaw
To All on this message board who have a 2005-2008 Mustang. I am currently sitting at the dealer having my alternator replaced after receiving the dreaded P0340 P0344 error codes. But while sitting here I also found that my lower engine cover was missing! Apparently the Dealer and other oil change places have a bad habit of removing this cover in order to get to the oil filter, and they either inadvertently forget to put it back or they intentionally forget to put it back because its a pain in the butt. That being said, I implore all of you to make sure you have your lower splash shield in place, otherwise you will continue to have your alternator fail due to dirt and water getting in it. If your engine compartment is showing signs of splash back or mud, you have probably had the lower engine cover removed by a lazy mechanic. See link below http://www.partsgeek.com/mparts/skid_plate/ford.html
Old Dec 28, 2011 | 12:14 PM
R1nStang's Avatar
R1nStang
I hit a raccoon last weekend and 90% of the splash guard is gone. I came across partgeeks.com while searching for it and thought maybe the $15 for splash guard and the $8 for the lower bumper insert were just crazy low prices..but figured i'd order it anyways...got the parts in and they are perfect. I can vouch for partsgeek.com the prices are too good to be true...but they are true.
djbigskrilla
Sep 20, 2022 01:04 AM
1987gt40ttopt
Aug 28, 2015 10:49 PM
5.0pntydrpr
Aug 27, 2015 10:26 PM
dba Brakes
Aug 21, 2015 07:07 PM
Jacob4589
Aug 8, 2015 11:00 AM
