heater core
Old Dec 6, 2003 | 09:14 PM
jason21378's Avatar
jason21378
Default heater core
hi i have a 1995 mustang conv 3.8L.I think my heater core is bad i am leaking antifreeze i am loosing a littlenot alot my heat blows out cold air. my friend thinks it isthe heater core. it takes a long time to get the heat to work. how hard is it to change a heater core in a 1995. do i have to take the whole dash out?
Old Dec 7, 2003 | 12:59 AM
vfast's Avatar
vfast
I ♥ Acer
Default heater core
there not the easiest one to change..several hours for removal I think
Old Dec 7, 2003 | 01:21 AM
vfast's Avatar
vfast
I ♥ Acer
Default heater core
when you install in put in a radiator fiter it goes in to top hose
Old Dec 7, 2003 | 01:47 AM
jason21378's Avatar
jason21378
Default heater core
thanks for info
Old Feb 19, 2004 | 06:59 PM
mmoto68's Avatar
mmoto68
Default RE: heater core
I have a 95 GTS. You have to pull the dash.
I had replaced the radiator earlier since it was leaking.
I later developed a small leak also, thought it was the heater core, it wasn't.
Make sure the bypass hoses and the cheap fittings that go into the engine are OK before you pull the dash.
Old Feb 19, 2004 | 09:40 PM
Buzzstang's Avatar
Buzzstang
You dont have to pullthe dash all the way out of the car. just drop the steering colum and then the dash will lay down on it and you can get right into the heater core. it is a pain and if you can afford it take it and have it done.
THANKS
Cody
djbigskrilla
Sep 20, 2022 01:04 AM
mrtrodonet
Sep 19, 2020 03:12 PM
Seanam
Oct 4, 2015 10:15 AM
Calizic
Aug 28, 2015 01:46 PM
Mnuckolls
Aug 9, 2015 08:54 AM
