Intakes
Old Aug 6, 2011 | 08:31 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default Intakes
What exactly are the differences between an 86 intake and a 87+ intake? I know that in 87 they increased the throttle body size, but is that it? I have a complete 86 intake and was thinking about just buying an 87+ throttle body, but wanted to see if there were any differences before I did.
Old Aug 6, 2011 | 08:50 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
That is the only difference between the 2. Then if you go farther into the motor the heads are different also. I'm sure you can find stock 87+ TB's all over the place but I would look to go bigger for the same price. Look for an Explorer 65mm and do the slight modification.
Old Aug 6, 2011 | 08:53 PM
1slow67's Avatar
1slow67
ROTM Moderator
I have a set of E7 heads sitting in the garage, they were on my first 302. I've got a 92 lincoln 302 in it now so I'm not sure what kind of heads it has.
I'll look around and see what I can find. I will only be doing this if my 67 doesn't sell.
Old Aug 6, 2011 | 09:02 PM
projectresto83
M.A.D. Motorsports
92 lincoln had e7's from the factory...Same motor as the EFI mustang
Old Aug 6, 2011 | 09:11 PM
1slow67's Avatar
1slow67
ROTM Moderator
Ah sweet, I might have to add EFI to my list of things to do if mustang doesn't sell. I plan on swapping the interior out first.
Old Aug 6, 2011 | 09:12 PM
rtintwo's Avatar
rtintwo
Double check what year and model of lincoln it came out of. If it came out of a town car then it is not an HO. If it came out of a MK VII then it is a HO.
Old Aug 6, 2011 | 09:17 PM
projectresto83
M.A.D. Motorsports
....I did assume it was a Mark VII like said above....easiest way to tell, which way does the intake face....toward the pass is a HO....driverside is a non HO with E6 heads
Old Aug 6, 2011 | 09:20 PM
1slow67's Avatar
1slow67
ROTM Moderator
Yeah its a non-HO, it was from a town car. But it feels faster than my old HO motor.
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
