Question about gears
Old Sep 7, 2005 | 09:18 PM
T1H5ON's Avatar
T1H5ON
Default Question about gears
who did you guys have put your gears in? should i have the local for dealer put them in? How much did you guys pay? Gears are in the mail, please help
Old Sep 7, 2005 | 10:46 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Question about gears
Personally I would never let a dealership service dept. touch my car, unless it was for warrenty work, the techs generally are not accustomed to doing performance type work (I know there are exceptions, so if a tech sees this don't take it personal). Find a shop that is used to doing performance mods on cars and Stangs in particular, ask around some local shows or cruise nights, there is bound to be a shop that is reasonably close to you. As for cost it can vary but I would plan on spending at least $250. Don't forget to have your speedometer re callibrated after the swap.
Old Sep 8, 2005 | 01:35 AM
95stangergt's Avatar
95stangergt
yea i agree w/what he said...that is what i did went to a local person and got them to do it. match sure you get all the hardware needed i think it is around $50. whatever you do..dont try to do it yourself or go to Ford...if they do it right it will cost you an arm and a leg...cost range from 250-350. mine was like 350 cause i didn't have hardware and this guy was the best around my region. ? for the guy that replied before me: why do you have to re cal ur speedometer? i know you go alot faster. my top speed was like 130 and now i hit 145 and it wasn't letting up but the road was coming to an end. do you have to cause i would go past the register?
Old Sep 8, 2005 | 02:01 AM
ShadowDrake's Avatar
ShadowDrake
ORIGINAL: 95stangergt
If you don't recalibrate your speedometer it will read considerably higher... your mileage will then be incorrect because it thinks you're going faster than you actually are.
Old Sep 8, 2005 | 12:54 PM
02StanGT's Avatar
02StanGT
I had a shop that does the dyno/tuning, put mine in. I had everything and it cost me $250, and they some redline fluid in there as well.
Luke9222
Oct 22, 2015 11:55 PM
musnicki
Sep 23, 2015 07:11 AM
Mustangmalo
Sep 6, 2015 05:22 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
