clutch question...please help
Old Feb 28, 2012 | 05:55 PM
whitestangergt's Avatar
whitestangergt
Exclamation clutch question...please help
just recently instaled a zoom street/strip upgraded clutch on my 97 gt with the help of my dad. clutch went in with no problems and works fine, the only thing is, this anoying rattle when the clutch is engaged (clutch pedal vibrates, and theres a continuous "squeak") i think the squeak is from the TOB but im not sure because its brand new. ive tried the quaderant adjustment trick but it dosent seem to take the rattle/squeak out of the pedal. also when shifting gears as i release the clutch out i can hear a tick or pop sound twords the top of the travel and thats when the ratteling squeak start. any help would be greatly appreciated
Old Feb 29, 2012 | 05:37 PM
craig71springsport's Avatar
craig71springsport
That's really weird, becuase my brother's 2000 GT did the same noise, but only when he completely destroyed the throw-out bearing.
Old Feb 29, 2012 | 05:38 PM
craig71springsport
Actually my mistake, his "popped" when it met the end of the pedal travel and only made the noise completely compressed, but still, it sounds like you just described what happened to his car.
Old Mar 1, 2012 | 08:30 AM
whitestangergt
I have the same "pop" at the end of my pedal travel aswell. Along with the constant ticking. Its driving me nuts I think ill stick my hand up in the tranny to try and grease it. Also do you know if there's suppose to be a gap inbetween the tob and pressureplate or does it rest on it 100% of the time
Old Mar 1, 2012 | 10:00 AM
whitestangergt
Update: took the stang for a spin this morning and it drove like a dime. Clean shifts no squeak or popping noises. I noticed it starts to make noise when it gets hot. I'm thinking the grease job might do the trick.
Old Mar 1, 2012 | 09:45 PM
stang06lv's Avatar
stang06lv
My 06 use to do this when it was really cold, Just means you need to drive it harder...or you could add some grease if you really want too.
Old Mar 2, 2012 | 02:37 PM
whitestangergt
Now the release lever is shakeing like a bi*ch. I wounder if it came off the ball stud. Guess me and my old man will have to rip the tranny back out again uggghhh
Old Mar 4, 2012 | 06:41 PM
craig71springsport
Yeah man hell with it, just rip it apart again...best to replace it now rather than when you're on the road giving it a chance to cause a wreck or some crazy **** and put your whole ride in jeopardy. Anything can happen and anything is possible.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
