cleaning/painting engine parts
Old Mar 7, 2012 | 09:17 AM
9550's Avatar
9550
Default cleaning/painting engine parts
so, for starters, my upper intake is about 15 years old and looks like ***.
lets say i take it off, which im planning to do, how do i go about getting the original paint or whatever it is, off (its flaking in several areas)? wire wheel? sand blasting?!?!?
the plate on the intake is corroded. wire wheel as well, or some type of solvent/cleaning agent? sand blasting?!?!?
then, aside from powdercoating, im guessing some type of high temp paint is the only choice? any recommendations?
is there anything that can be done for heads, if for nothing else than to just knock the rust off them? wire wheel again?
thanks in advance
Old Mar 7, 2012 | 07:03 PM
stevednmc's Avatar
stevednmc
Wire wheel...bead/sand/walnut shell blasting is faster though, works well.
Old Mar 7, 2012 | 07:37 PM
9550's Avatar
9550
yeah, i watch alot of american restoration. wish i had one of those sand blast setups.while im wishing, i wish i had a spray booth as well.
i will almost certainly end up going the wire wheel route. do i have to start getting into wire stiffness, thickness, anything like that to avoid damaging the surfaces?
Old Mar 7, 2012 | 07:44 PM
stevednmc's Avatar
stevednmc
Generally, a wire wheel isnt going to hurt anything, most likely it will be softer than what your working on. You have to be careful of abrasive type wheel because they can remove material faster, Just pay attention to your work and you'll be ok. Especially pay attention to aluminum as it is soft metal compared to steel.
I wish I had a decent sized garage with a freakin lift!! I live in an aprtment and cant open the doors all the way in my little garage...I also wish I had a media blaster...paint booth..etc..
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
movielover40
Aug 27, 2015 10:13 PM
inyadreems
Aug 21, 2015 09:10 AM
Jacob4589
Aug 8, 2015 11:00 AM
