rear seat removal
Old Sep 18, 2005 | 03:38 PM
Mustang Mommy's Avatar
Mustang Mommy
Default rear seat removal
This should probably be in a different forum. But, I need to know asap. How do I remove my rear seat in my 2000 gt?
Old Sep 18, 2005 | 03:56 PM
Speed_racer's Avatar
Speed_racer
Default RE: rear seat removal
Pull the carpet out in the trunk. Im pretty sure you might have to push the back of the seat down. Look for a couple bolts and viola!
Old Sep 18, 2005 | 07:24 PM
IWinULose's Avatar
IWinULose
NO don't pull the carpet out... Underneath each side of the rear seat is a button. push in both buttons and the lower part of the bench will come out. then, pull off the plastic piece above the backrests. be careful as to not break the tabs, once this is done... you will be able to unbolt the seats and the backrest frame with the back rests attached.
Old Sep 18, 2005 | 08:56 PM
Mustang Mommy
Thanks. I found the two buttons. One in the middle of each side of the rear seat. I only had to push those in and the bottom half came right out.
The rest was easily accessed after that.
Old Sep 18, 2005 | 11:37 PM
PipsBlackStang's Avatar
PipsBlackStang
That would have lead to nothing but troubles..
Dragonus18
Sep 9, 2015 01:21 AM
v8sn95
Sep 7, 2015 10:17 AM
Doogie65
Sep 6, 2015 02:55 PM
cbird1177711
Sep 2, 2015 08:51 PM
Sep 1, 2015 08:16 PM
