Guages Going Crazy
Old Apr 24, 2012 | 07:46 PM
ShakenRoush05's Avatar
ShakenRoush05
Default Guages Going Crazy
2005 4.6L 3V Mustang
Over the past week my fuel gauge for no reason with 3/4" of a tank went well beyond full (almost 3:00). I disconnected the negative cable and then reconnected and the gauge behaved normally! The following day the temp gauge would only read at about 10:00 where normally it sits at 12:00 (these are non numerical Roush gauges! Finally today, my tach is stuck at 2800 RPM as if that was zero!
Has anyone experience this erratic behavior and what was the fix!
Thanks to all who respond!!!
Shaken
Old Apr 24, 2012 | 08:36 PM
craig71springsport's Avatar
craig71springsport
A fuse perhaps?
Old Apr 25, 2012 | 08:31 AM
ShakenRoush05
Update:
My tach is now back to normal! So has anyone experienced this phantom behavior??
Old Nov 27, 2012 | 03:02 PM
N4SER's Avatar
N4SER
My gauges (stock) are also acting up. The first one to act up was the voltage gauge. Noticed it a day after i removed the battery to test an audio amp. First it read at the lowest, then it did a 180. Now it sits at 9:00 ant hasent moved for months. The temp gauge also acts up. It will stay in cold forever and sometimes it will show actual temp. The last one to act up was the fuel gauge. It did exactly what yours did. Now its sitting at around 3:00 I have no idea what it is.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
firecoyote
Sep 27, 2015 02:37 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
96stang3.8
Sep 10, 2015 06:42 AM
