Pinion seal?
Old Jun 7, 2012 | 02:24 PM
Finallyverted's Avatar
Finallyverted
Talking Pinion seal?
I am getting some gear oil where the pinion seal meets
My car only has 47000 miles on it it's an 03 gt convertible
Is this normal? How do I stop from having to do it again?
Is there a stronger aftermarket part? Or should I just replace
Crush sleeve and seal? THANKS for the help in advance
Old Jun 7, 2012 | 04:41 PM
stevednmc's Avatar
stevednmc
No leak is normal....you should replace the seal. Mileage is only part of the equation, your car is nearly 10 years old now, some seals are bound to go bad.
Still thinkin on your convertible top issue.......
Old Jun 7, 2012 | 08:48 PM
Finallyverted
Talking
Thanks so much! Will have it done next week, top issue I found the 99-04 top leak thread I'm thinking I have same issue will look further into it Monday thanks again, posted pictures on other thread about top tho
Old Jun 8, 2012 | 09:55 PM
stevednmc's Avatar
stevednmc
Do you mean the leak on either side of the rear window? Because I was gonna suggest that...
Old Jun 8, 2012 | 10:24 PM
Finallyverted
Ya haven't looked at the hole with top halfway down but it's the same spot that is leaking
Old Jun 13, 2012 | 07:21 AM
Finallyverted
I have a shop I have deal with for a while now, should I have this guy replace or should I bring it to a transmission shop (also knowing ) ?
Old Jun 13, 2012 | 04:54 PM
Old Mustanger's Avatar
Old Mustanger
A Pinion seal leak should not be tolerated, it should be replaced as soon as feasible. Sometimes they can get catastrophically worse in a short time. I once had a small leak in an Oldsmobile rear end. It really leaked very little, but one day it catastrophically failed and leaked out all the lube in a short drive. It seized the rear end and the whole rear end had to be replaced. It would have been a LOT cheaper & easier if I had only replaced that damn seal.....
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
bradleyb
Nov 27, 2015 07:50 PM
KingRando
Oct 2, 2015 08:06 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
