Whats wrong....wont start??
Old Sep 28, 2005 | 12:22 AM
ByPopularDemand's Avatar
ByPopularDemand
Default RE: Whats wrong....wont start??
ORIGINAL: GreyStang
well it could be "both" if the wires have corrosion on them..
Even a car with NO battery at all should still jump start especially if the "jumper car" is running...
Really my old car would not hold a jump with the battery in but after a new battery and alternater it started fine using the old wires
Old Sep 28, 2005 | 01:00 AM
Dan9687's Avatar
Dan9687
Can someone explain what it does and where the "solenoid" is actually located???
Old Sep 28, 2005 | 12:31 PM
02StanGT's Avatar
02StanGT
On the starter. It engages the starter with the flywheel (pushes in a gear). Just replace the battery, or your friend can push start his car if he doesn't want to buy one. The solenoid should be fine if you here a clicking when trying to start it. The battery just doesn't have enough power to turn the starter.
Old Sep 28, 2005 | 04:37 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, the old mustangs had the solenoid separate fom the starter, but you guys have it attached to the starter. Take your starter into a parts place and have iit checked.
Old Sep 28, 2005 | 09:18 PM
Dan9687's Avatar
Dan9687
I've heard that before....push start, what exatly does this mean?
Old Sep 28, 2005 | 09:22 PM
pj1010's Avatar
pj1010
Get the car rolling, in gear, clutch engaged, ignition on. Roll fast enough so that the car has enough momentum to transfer rolling power from the wheels into turning power for the engine. Ease of the clutch, give it a little gas, and bam, car should be running.
Old Sep 28, 2005 | 10:31 PM
Dan9687's Avatar
Dan9687
awesome trick...would it work though in my friends case with his battery dead/alternator???
Old Sep 29, 2005 | 12:06 AM
ByPopularDemand
If the alternater is done the battery woulnt charge. If its a dead battery it will get you around but i heard push starting often is bad for the car
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
