#5 cylinder Misfire PLEASE HELP
Old Dec 6, 2012 | 10:20 AM
jcmansu's Avatar
jcmansu
Angry #5 cylinder Misfire PLEASE HELP
I bought this car in may of this year and after about 3 months i started getting the tuggin, weezing, and it got so bad it finally triggered my check engine light
WE HAVE DONE A COMPRESSION CHECK- FINE
CHANGED COIL PACKS
CHANGED WIRES AND PLUGS
CHANGED THE CAM SENSOR, CRANK SENSOR, FUEL FLOW SENSOR
CHANGED THE NUMBER 5 FUEL INJECTOR
REPEATEDLY CHANGED THE NUMBER 5 SPARK PLUG WHICH WOULD BE FOULED OUT.
STILL DOES IT, MAN I HAVE SPENT A TON OF MONEY. PLEASE HELP. DO YOU THINK IT COULD BE THE PCM ? OR WHAT ?
Old Dec 6, 2012 | 10:22 AM
jcmansu's Avatar
jcmansu
OH YAH WE CHANGED THE EGR SENSOR ALSO. AND THE CHECK ENGINE LIGHT HAS COME ON 4 TIMES AND IVE BEEN TOWED 4 TIMES
Old Dec 6, 2012 | 05:56 PM
Mike T's Avatar
Mike T
CHANGED COIL PACKS
If you have a check engine light coming on, you need it checked for codes. Quit guessing what's wrong with your car.
Old Dec 6, 2012 | 11:40 PM
petrock's Avatar
petrock
+1. If you want to fix something, take a small screwdriver and remove the caps lock key from your keyboard.
If the #5 plug is fouling then you have an issue in that cylinder. Probably head gasket, but you won’t know until you read the codes to verify its a #5 misfire, and then tear into the motor. Good luck...
Old Dec 7, 2012 | 08:25 AM
jcmansu's Avatar
jcmansu
Thumbs up
I cap lock most of the time because its easier for me to see. And thank you for all the input, i will pass it on to my mechanic
thanks
Cindy
Old Dec 7, 2012 | 11:19 AM
Stevo86's Avatar
Stevo86
If that is your mechanic shotgunning parts like that you need a new mechanic. I would have been fired for that many attempts and still having a car come back. Probably like 6 parts ago...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
b8checker
Sep 30, 2015 07:11 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
