switching to synthetic
Old Oct 4, 2005 | 08:28 PM
NewMexMustang's Avatar
NewMexMustang
Default RE: switching to synthetic
Cool, I'm only at 15,000. I guess I'll plan on 30,000 just for good measure. I'm thinking Royal Purple - for my next oil change too. Since I've heard so many good things about it.
Old Oct 5, 2005 | 10:58 AM
redmustang83596's Avatar
redmustang83596
i have always heard that after you have a lot of miles on a motor and youve been using regular oil for the whole time, that its not a good idea to switch to synthetic oil... it doesnt saturate the seals as well and could cause them to crack and leak, big reason i didnt switch on my 83 convertable 5.0 with 150,000 on it.. my buddy had an eagle talon with like 130K on the motor and he switched to synthetic oil and 2 months down the road he was burning more oil then gas, then like the dumba$$ he is he didnt check it at all, the oil completely ran out and he trashed his motor... dont know if they are directly related but the exact thing happened that i was told would happen so my recommendation would be to not switch to synthetic on an older motor
Old Oct 5, 2005 | 12:18 PM
nitrous_bob's Avatar
nitrous_bob
ORIGINAL: redstallion
wal-mart sells super-tech brand fully synthetic oil...5 quart jug for about $12...
so i think i will try that stuff
worst case scenario i guess i'll go back to dino oil
also, is synthetic more likely to leak or have any other negative effects on an old engine???
i don't see how thats possible.....even the cheapest brand is $2.99 a quart....that might be a blend
absolutely go synthetic...power steering and rear gear lube as well.
you'll pick up a noticible gain in mpg, and the oil is still gold after 5k miles
not to mention that you can get 15w50 for those older cars that need to increase compression a little
i don't advocate the blends....go full or stay home
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
guitarman376
Sep 30, 2015 05:54 PM
Colin Ringle
Sep 15, 2015 09:27 PM
IronRaptor
Sep 9, 2015 08:10 AM
